new here from maine. H22 eg
eg6-jarhead
hey guys & girls.
im new here but not to hondas.
there isnt a day that i dont think about going faster.
i believe im a true honda head :)
i'll start my intro with some hondas that ive owned/currently own.
first car:
1994 civic dx hatch 5spd
charcoal
bought it at 16 yrs old.
swapped in a d15b cause the b7 was smokin like a bastard.
man i miss how simple my life was when i had this car :)
mocked up my first turbo project on the hatch:
then the 1st hatch wouldnt pass inspection.
so i kept it as a parts car and bought a red 1995 dx hatch (riced).
i removed the halo lights, eyelids and front mount intake lol.
then i boosted it with the kit i had mocked up on the black hatch. car went 14.6 @ 94 1/4mile.:
then i built a d16z6 for the red hatch. typical eagle/srp combo.
never got it running right. sold the turbo stuff, and kept the built block.
sold the red hatch. bought a white 1992 white cx hatch. still own this one, its my r&d whore.
swapped a stock z6 into the white hatch cause i couldn't deal with the 8 valve that was in it haha.
car ran 15.5 @ 94 1/4mile just how it looks in this pic:
then i boosted the stock z6 with a 14b. car ran 9.3 @ 76 1/8th mile.
no traction due to crappy track prep:
then i thru the built z6 block that i had in the red hatch in it.
car made 300whp on 20psi. never got to track it cause i cracked a sleeve:
now im going turbo h22a with a gt3582r turbo. still in the making.
and a quick pic of my old daily driver wagon and my jeep:
1991 wagonthing. stock everything except fart can and tow hook. cut springs and knock off 15" slipstreams:
1989 cherokee with wayyyyy to much to list lol.
enjoy!
-jack
so i cracked a sleeve on my d16 in 2009 on 20 psi. after that i got out of the sohc game, and picked up a jdm h22a with 70k on it.
put the car on the road in august of 2010, n/a car went 13.3 @ 104. not fast enough.
this winter there are major changes happening in the set-up.
current mods/parts list:
jdm h22a 60,000 miles on it
innovative billet aluminum engine mounts
type s cams
kaizen speed balance shaft eliminator kit
arp headstuds
skunk2 intake manifold
aftermarket intake
brand new headgasket
brand new timing belt
type s crank pulley (1 groove)
12lb flywheel
dragger clutch, 6 puck sprung hub
dual diaphram pressure plate
custom axles
full integra disc brake swap front and rear
energy suspension rear trailing arm bushing
blox lower control arms
rear lower and upper tie bars
front upper strut bar
skunk2 coilovers
brand new rotors and pads front and rear
brake line tuck
charcoal canister removed
full 3 inch exhaust from the collector back
flowtech chambered muffler
summit racing resonator
1000cfm slim fan
dual core radiator
new alternator
new plugs
walbro 255lph fuel pump
buddy club seats
stripped interior
tach in gauge cluster
vdo oil pressure gauge
integra front sway bar
4-2-1 stainless header
spoon mirrors
rota circuit 8's powder coated white
bfg kdw's 205 50 15
6k HIDs
SS brake lines
15/16ths master cylinder
carbon duckbill
im sure there is a lot im not remembering.
the car has a custom tune on it via crome free. i still get 30+ mpg highway
best time to date is 13.393 @ 104mph.
this winters project: BOOST.
for 2011:
blueprint mfg sleeves
manely rods
cp pistons
skunk2 pro 1 cams
skunk2 cam gears
arp mainstuds
gt3582r 3" vband exh-housing
big FMIC
supertech valve train
hks ssqv
rc 750's
custom built topmount manifold
twin 38mm wastegates
turboxs dual stage boost controller
lsd
24.5x10 slicks on lensos
I JUST WANNA GO 10'S!!! SO BAD haha
pics of this winters progress: (2010/2011 winter)
skunk2 pro 1's with gears
garrett gt3582r
manifold pieces: (disregard hx35 turbo, sold it and got the garrett)
how it sits currently before turbo
enjoy!
thanks
AWESOME! The car looks sick dude. Thanks for sharing your story. I'm looking forward to the boosted h22 build. You don't see those very often. I see that you joined 3 years ago and just now made your first posts:) Welcome
yea haha amazing i remembered my user name and password.
i joined back then when i was buying/selling stuff. now im here for good ;)
Nice build man, started out at the bottom and now worked your way up... Keep the pics rollin I would love to see a turbo H22 Hatch...
hey guys new here and also new to the whole forum thing. jarhead, quick question have u had any problems driving the h22? i have a 94 integra with a h22 and im having a couple problems just wondering if u could share some info..... thanks
i fixed every problem i was having.... shoot away
its hard to explain but today when i went to drive the car it wouldnt even make it to 3000 rpm and it felt like it was choking, but it didnt stall at all and it did it in every gear but then the check engine light came on and it didnt do it anymore. i didnt check the code, its obd1. any ideas?
maybe an electrical issue like a ground or something. especially if it is intermittent. try to get the code next time
