B18B1 Swap 97 Civic Lx Wiring Nightmare?
OK so ive had this swap in for a bit and always had a high idle so neva really took it on the road much.But i need this car running right for the summa so hopefully honda swappers can help.
Ive changed:iacv,timing belt,tb,intake manifold,map,tps,coolant
i dont have a fitv because im using a aftermarket intake manifold
But i didnt do the wiring on this swap and i wanted to go over it to see if its wrong:confused:
ITa 97 civic lx with a b18b1 obd2 motor i use the harness off the civic extended the rear o2,map ,tps,and iacv..for some reason ive had a itchy feeling its the wiring on the iacv anyone have a writeup on doing this mod?
Please help Out Will send some reap our way
i beleive the civic clip is a 2 pin connecter and i beleive an integra one is the same cuz my iacv on the b18 only has two pins comming out
97 LX comes stock with a 3-wire Iacv, so you have to convert the harness from a 3-wire to a 2-wire.Assuming that the B18B1 ecu is OBD2a all you have to do is this:
i already had this done but what colors on the wire do i match up with the clip?
