Please help! Just finished a swap of a B18b from a 1996 integra into a 2000 Civic hatch.
-The civic had a d16y7 non-Vtec before.
-Were using the d16 harness on the B18b. The B18b is OBD2a, harness is OBD2b
-BTW, we are running it with a OBD1 integra B18b ECU (OBD2b to OBD1 conversion harness)
We did the 3-wire to 2-wire IACV conversion, and did the same thing on the CKP sensor. As well as lengthened the Primary o2 sensor, and a couple others.
Start it up, it starts easily, but runs like crap. Sounds like its misfiring or not runing on all cyls. But I tried removing one spark plug wire at a time while running and it seems like each one made a difference, so that would make me believe all 4 are firing somewhat. It shakes quite a bit. Im just clueless I have no idea what to do or dont have any ideas...
Got a CEL for #9 - CYP: Cylinder Sensor - P1381 (intermittent interruption), P1382 (no signal)
Tried putting a different distributor from my DD integra on it and it didnt really make any difference at all.
Check out the video. Its kinda shitty but all I could get. Just click on it to play.
