Hey guys,
Not going to bore you all with a long story...
situation: Starter bolt bracket broke, so JB welded the bracket back on, replaced, started fine, was driving down the highway and hit a bump, all of a sudden now...
Car in ANY Gear = NO movement..
When using the gear shifter it just slides into any gear with/without the clutch in.. it doesnt seem to make a difference.
I can HEAR the gearbox putting it into gear, and even REVERSE will not move the vehicle.
when in 4/5 gear it sounds like somethings grinding.. while it just sits in gear with no clutch it or anything.
Now.. : I changed the clutch 650KM ago, everythings been fine, no problems what-so-ever. this happened on the highway while in 5th gear doing 110KM/H.. not speeding, anything.
Any help/suggestions/tests would be great thanks guys!
