HELP ME FAST!!! will a b series fit in a 99 ex?
Shadowlid
My engine blew up on me i need to know if a b18 will fit in it. With out any mods.
Is that a trick question?
If not, try including some specifics. :huh:
I didnt think it would fit either.. until I applied more pressure.:p
B-series motor/trans/ECU/axles/shift linkage/rear trans mount.
If running a B18C....knock sensor and IAB's needed to be ran to the ECU too.
If running a B20......B18B intake manifold needs to be put on the B20 block for hood clearance.
:fosho3:
