Antenna wire
Status
Not open for further replies.
which color is the antenna wire under in the dash? I put in a new auto antenna, and now i gotta hook it back up, so yea, which wire is it?
could you not just plug it into the wire at the back of the car? what year/make/model are we dealing with? factory radio? detailos...
its a 1990 honda prelude 2.0 si. kenwood KDC322 deck, and a stock wiring harness from the prelude. I would like to know which wore to connect the Antenna to. My antenna is autommatic
here ya go
HONDA/ACURA
P o w e r
Memory (+12v Constant) Blue/White
Ignition (+12v Switched) Yellow/Red
Ground (-) Black
Illumination Red/Black
Dimmer (none)
Power Antenna Yellow/White
S p e a k e r s
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
PIONEER
P o w e r
Memory (+12v Constant) Orange
Ignition (+12v Switched) Red
Ground (-) Black
Illumination Yellow
Phone Mute Yellow/Black
Power Antenna Blue
S p e a k e r s
Right Front (+) Gray
Right Front (-) Gray/Black
Left Front (+) Green
Left Front (-) Green/Black
Right Rear (+) Gray/Red
Right Rear (-) Black/Gray
Left Rear (+) Green/Red
Left Rear (-) Black/Green
i have more
SONY, ALPINE
P o w e r
Memory (+12v Constant) Yellow
Ground (-) Black
Dimmer Pink/White (Alpine only)
Power Antenna Blue
Amplifier Turn-on Blue/White
S p e a k e r s
Left Front (+) White
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
FORD
P o w e r
Memory (+12v Constant) Green Yellow
Ignition (+12v Switched) Yellow/Black
Ground (-) Black or Fat Red
Illumination Orange
Dimmer Orange/White
Power Antenna Blue (varies greatly)
S p e a k e r s
Right Front (+) White/Green
Right Front (-) Green/Orange
Left Front (+) Orange/Green
Left Front (-) Light Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/orange
Left Rear (+) Pink/green
Left Rear (-) Pink/Blue
Originally posted by hcivic.com@Sep 23 2003, 05:16 PM
PIONEER
P o w e r
Ground (-) Black
Illumination Yellow
Power Antenna Blue
S p e a k e r s
those are the old school Pioneer colors just to keep things straight. Pioneer switched to standard EIA colors in 2000.
dimmer is orange. The pink on Alpines is the mute.
Originally posted by rudeludenotmeanthough@Sep 23 2003, 06:21 PM
thanks, i just needed to confir that it was the yellow white. its the only one that is not hooked up in the dash :p
Again, thanks.. that should be refrenced
what happened to the guess and check method . . .
its one of my favorites
i was affraid i would fry something.
installing new stereo...
here ya go
HONDA/ACURA
P o w e r
Ground (-) Black
Dimmer (none)
S p e a k e r s
PIONEER
P o w e r
Ground (-) Black
Illumination Yellow
Power Antenna Blue
S p e a k e r s
I was installing my new stereo first taking out the last after market stereo. The last one was wired wrong so that the stereo restarted everytime I turned off the car. In otherwords. I'd have to start my CD over from the beginning, and settings for sound and such would go back to default. I'm assuming it's because whoever installed the stereo hooked the wire that is supposed to be hooked to the blue/white 12v constant to the yellow/red 12v accessory wire instead. The problem I have now is, I can't locate the blue/white wire anywhere except paired with an additional brown/white wire(there is another brown/white wire where is should be with all the other wires needed to hook up the stereo) with a male end connector thingy. This pair of wires was not pluged into anything. Do you think that blue/white wire pared with that brown/white one is the 12v constant or something else?
Status
