seat question
rustbucket
after reading online that dc teg seats bolt up to eg civics, i went to the junkyard and pulled the front seats from a 94 teg, vacuumed / steam cleaned them, and dyed them black. when i go to bolt them up the two outside bolts go in fine, but the bolts wont go in on the inner side, the holes are too high - is there something im missing or did the junkyard mislabel the teg?
these seats will bolt right in
these wont
these wont
thanks man but the reason i dont know if its a da or dc is because the body panels are stripped off at the yard, i had to go by the year painted on the window. said 94, which would be dc unless it was one of the last DAs made or the junkyard fucked up. here's pics:
what a mess, dont see an edit button though. you can see how high the rear inner hole is on my drivers seat, i can fit my fingers underneath it. even if i got a longer bolt it would never be flush with the floor. the front inner side is a little better, looks like if i wiggle it around a bit i might be able to make it fit
You can't edit until you are out of greenhorn status.
hard to say.. they both had a similar design.. i'm guessing they're DA seats .. swap the rails from your civic seats
another reason i think they're DA seats is because DCs didnt come w/ solid color cloth seats that i know of.. thought they all had some sort of design in them
They did have a pattern, I just dyed my whole interior + the seats. Must've been a late 93 model sold as a 94. Thanks for all your help brother, ill google around on how to swap rails
Should be able to just cut the rings and swap the whole pan.
yeah i have swapped rails on several sets of seats, takes about 10 minutes a seat. those are definitely DA seats.
