ImportAutoPerformance
Alright guys, here is the scoop:
We are new to both Honda Swap and carrying BC coilovers so we wanted to start things off with a huge bang. Therefore, we are offering the BC Coilovers at the lowest allowed price plus FREE shipping AND a $75 store credit!
EG/DC/EK Model Numbers are $900
All other Honda applications are $1000
Plus FREE FedEx Shipping
Plus $75 Store Credit*
You can purchase your coilovers and then make a second order for camber kits, ASR subframe brace, or whatever you like! Keeping in mind you will get $75 off!
*An important note. The $75 credit can be used towards a future purchase placed within 30 days of your coilover order. Shortly after your order is processed, we will email a coupon code to use during checkout.
EG Coilovers: Click Here
EK Coilovers: Click Here
DC Coilovers: Click Here
All Other Models: Click Here
Info on BC Coilovers:
The BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. Pricing is for a complete coilover system including all 4 wheels!
BC Racing BR Series Application Features:
Detailed Technical Features common to all BC Racing Coilovers:
Please let me know if you have any questions!
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Concave lower locking ring
- Pillowball front mounts with rubber rear mounts
- Separate full length height adjustable
- One year warranty
- Rebuildable
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating
- Springs are made of SAE9254 high strength, durable steel. Compression tested over 500,000 times with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
