OK so a year later i am going to do this again and i am pretty sure that i can make this work. The only problem i had before was that once i got the prelude lower control arm on, hub and knuckle on and the prelude sway bar mounted. (which is bigger around and i could not use the prelude lower control arm without it) I realized that the sway bar was hitting the shock ever so slightly, for those of you who know the prelude it has essentially a tie rod end that attaches to the sway bar, and only two bushings instead of four that attach to the control arm so it can sit at a angle instead of straight up and down. So i am going to get new rotors and ceramic pads (i work at a parts store so not bad for me) and put it back on when i get a couple days off, and just heat up the sway bar and bend it just a little so it wont touch. And i think this will be a feasible swap. At the moment i am only going to do the front. And as i am doing with this i will take pics and then do a wright up on how to do the swap, and once i look and compare the rear end i will do the same for that.
