why the harness?? just drop the motor in w/ the 97 ecu.. everything should plug right in and bolt up.. other than a couple sensor you wont be using
Unless the chassis connectors are different I dont see your point.
i would take the motor harness and ecu and put in the 96
they're the same... you're the one that said to swap the harness
the harness in the 96 will work fine.. 2 connectors wont be connected.. vtec solenoid and knock sensor
just use the 97's ecu w/ the motor..
His Dick is bigger..... do what you want
