just finished my swap and i got sum ?? b18a1
mattyoung2002
i just finished my b18a1 swap in my 90 civic si hatch and i had it running just fine and then it jus cutout and died and it dont even turn over now any ideas
A plug not connected all the way. Maybe distributor or even ecu. Seems silly but they small stuff usually os the culprit.
well i went over every wire and plug i was actuley able to get it to turn over one time without the dist. pluged in and now it wont do nothing at all. i know when u turn the key to the on position the distributer starts to hum and its a new dist.
what? distributor hum..................hmmmm... you mean fuel pump.
check your grounds, hondas has three grounds. Most important the one on the thermostart housing.
