I got a 2000 civic automatic single cam, I'm trying to put a 95 integra automatic swap in it but dnt knw wht I need ??or can it be done?? I have the whole 95 integra car with everything !! So what should I do?
Engine mounts/ dc to ek. (D to B series) try hasport.com or egay
Ecu Jumper harness obd2b to obd1 (depending on which ecu )
Possibly ek Si axels, ( Ive heard different opinions on this)
Some engine harness differences to situate.
The only downfall is the automatic trans.
Good Luck..
I might be interested in your Y7or8 (old motor) if its not shot and willing to ship.
OBD1 -> OBD2 car, annoying, pretty sure that the tranny mount is going to be an issue, not 100% though, the wiring isn't that bad from what I remember, but then again my brain is tapioca. You'll need the swap parts from a 99-00 SI. Ideally if you could source a 99-00 SI, you'd have pretty much everything to make it a fairly painless swap.
I would look for an OBD2 integra, it would almost be a strait bolt in mounts, axels, ecu ect... there are plenty of autos around... where I would look... 98+ just me tho
