A question about engine swap for 2001 civic
Ease and cost I'd probably stick with the K series. Can you do all the work? fabricate things like mounts? Rebuild wire harness'?
I wish iknow how~it must be so much fun
how much it cost for find a carage to swap it?
Prices about ten years ago were in the neighborhood of $400-$800, usually, depending on what all had to be done, nowadays with some of the more complicated swaps I can see it getting a bit higher.
really you should just stick with something k series. its doesnt have to be a k20... there are lots of k24s from accords and tsxs, and the accord ones are pretty cheap. just do some research, theres lots of info out there. k swaps seem to be getting cheaper to do all the time. in your chassis, a k swap is the only one that makes sense if you are on a budget.
