I am doing the same thing on my friend's 98 accord with F22 SOHC engine swapped to F20B DOHC Vtec with LSD Tranny. The only problems I am encountering is that the two main plugs from the right front panel under the fuse box. I changed them into the same color coded wires that corresponded to JDM F20B plugs and the ECU has 4 extra wires that needs to be solder into something? A plug - White/Black stripe and 1 silver paint, Red/Yellow stripe with 2 silver paint, Green/Red stripe (ELD)with 2 silver paint and Gray with 2 silver paint.
