I got a teg with a ls vtec swap with a spun bearing. Has a stock ls crank I need to no if I need to use a better crank like eagle. It has a built head edlebrock valves,springs,cams,cam gears,type r intake 72mm Ericks racing throttlebody dc header I think 2.5 full pipe high flow cat the bottom has eagle rods cp pistons 11.5to 1 comp rev limit is at 9500 sorry its my first Honda motor buildup I've done a lot of other stuff but not Hondas would love to get any help I can I'm not positive it has edlebrock cams that are marked M and 2 and on the back is eched ether HOBIN or HO8IN any help would be great and if I'm doing this I would like to do it the right way I already called eagle and got a new rod and I know I have to get a new crank but everyone said the stock crank can take up to 400 HP but can it take the rpms I want it to last its tuned to so save gas till vtec and the cams start witch is about 6000rpms the guy that spun the bearing said he was getting 32 mpg on the highway but I will use it like to have fun
