I want to know if this engine is ok for my 98 automatic. If this is possible then what would be my biggest problem doing it.
I would be willing to make manuel but i just need to know where to start.
Start here ...
Swap Articles - HondaSwap Forums
You car being automatic you can either convert to manual, or get an automatic B16A transmission. The conversion is a bit of work, you have to add the pedal set, the clutch lines, master cylinder, change the bracket on your car too I believe, but someone might make a mount that can use the auto bracket, not sure.
Would i be able to put any B series auto trans on it?
