dilbeckskate
infamous
title says all, it idles fine, but wont rev past 1500 rpm ? any ideas ?
the engine in the picture is from 88-91 car which used electronic advance ignition system - your 87 Si used a vacuum advance ignition system
did you modify the wiring so that you could run the electronic advance?
what ECU do you have? - you would need an ECU that is compatible with the electronic advance, like 88-89 Integra PG7 - you can't use the 86-87 Integra PG7 as it was also for vacuum advance ignition
