I have a '91 CRX Si with aftermarket, drilled rotors with EBC Greenstuff pads. I bought the car from my Dad last year and he doesn't remember what brand of rotors or calipers are on it or where they were purchased from (upgrade was done 8+ years ago), but says they could be Brembo.
With the drilled rotors (which are about 3x the thickness of stock rotors, I think) it can't possibly have the stock calipers on it, right?
So, how do I find out what calipers are on it so that I can get the correct replacement pads?
The brakes started to make some noise a few days ago and it's getting worse rapidly and I'm also not so sure that the wheel bearings aren't going as well. When upgrading brakes, there wouldn't have been a need to change from stock wheel bearings would there? Is there any such thing as upgrading wheel bearings?
So, how do I figure out what calipers and rotors I have and do I likely still have stock wheel bearings? I just want to make sure everything is done properly.
Thanks for any help you can provide! -J
