b16a2 questions
Luckyeg
Need help I've built my b16a2 for high compression I'm at 12.5 to 1 and my friend told me to supper charge it I really would like to just put a small Volvo turbo on and boost it at 6lbs what should I do
Really I want to go boost don't want to charge it have you ever done this with a high compression motor if so what turbo should I use
lower the compression.
Seriously. unless your going to run alcohol and c16 all the time, with like no timing. Lower the compression. You will never add 100 hp on pump gas to a 12.5:1 motor. Just not gonna happen
assuming the block will take the abuse i would look into zex nitrous system. either that or lower the compression and go boost.
I get ok power but I thought it might spool a small turbo
it is not a matter of being able to spool a turbo, it is a problem of the static compression being so high that under boost the dynamic compression gets so high that most fuels will not provide enough knock resistance. If you were building an all out drag motor that was going to run alcohol or nitro than it would be fine. running on pump premium and possibly even c16 you will end up with a blown motor.
My friend is going to give me a b1.8b vtech head if I built that head would I be Abel to bolt it on or what head swap can I do to get a little more power with me building it up like should I keep the b1.6 head or should I go b1.7 or maybe b1.8 head
a B18B is not a vtec head. Stay with the B16A head that you have. If you can get a B18B block than you can buy an LS/VTEC adapter kit to put your B16A head on it.
Ok bro what I'm going to do is buy a skunk 2 cams and valve train for the b1.6 and then ima just supper charge it ima start low for now I think ima just go 5 lbs and upgrade fuel rail injectors fuel pressure regulator intake mani and throttle body then Ina sell the car man I think I might keep it but idk yet cause there's not much more I can do really need help
Since you already BUILT your B16A2 then you should tune it for a 100 shot of NOS. I would prefer a DRY SHOT being that the compression is in the 12's. Build the head with some stage 3 camshaft, I prefer Skunk2 but you can go with whatever fits your budget. Dont forget to get the B16 head ports Matched and a 5 Angle valve job. For those Stage 3 camshaft you will need to upgrade your valvetrain so i suggest you do so if you want to see anything close to that 100whp gain. Skunk2 manifold and 68mm throttle body 2mm more doesnt make a difference but make you lose a bit of lower end torque because it will cause you to bog considering that you might do that 5 angle valve job( which is better for Air Flow [ in my opinion ]). That 100 shot should put you some where in the 300's
Ok thanks what ima looking at now was a stage 2 kit that is for high compression brings skunk2 cams valves springs and retainers port polish the head 50cc wet shot and a 5 psi electric supper charger and skunk 2 fuel rail and injectors 550cc
50cc Wet Shot? I have no idea what you are taking about.
Forget Turbo, you said you already built the motor.
I Dont get what you are trying do?
If you want a B16 with over 300HP+ then
get a 1.8 STROKER KIT
Darton Sleeve
Stage 3 camshaft
5 angle valve job
Upgrade valvetrain Kit
12:5.1
