k24/20 built Integra..32MPG 270HP
kteggy88
New Price $8800 obo
Hey testing waters on my integra.
Reason for selling: need the cash
Price: 10000 obo
This Build cost over $12,000. If you know anything about the k swap, you know it's not a cheap build.
never had a single problem with it at all. All of the work was done and tuned by Mikey from ProFunction..I believe it made close to 270hp/222ft-lbs. The car has 2000 spec front and rear bumpers. It has minimal rust bubbles in the quarter panels and some scratches that can be buffed out. small scuff on the bumper. It runs perfect. Oil is changed every 2k miles with mobile1 5w30. I only fill up with 93 octane from Shell.. Its a mid 12 second car with a set of slicks/drag radials.. Its a perfect daily driver.. Oil just changed a few days ago. all black interior. might need new brake pads soon (starting to squeak).If you want more pics, just ask! ac ps delete kit..still have ps pump if needed..Heater works great! I'll include the ScanGuageII with it also, it can find your mpg, mph, 0-60, 1/4 times, and tons of other stuff..If you have questions let me know
96 integra ls (about 102k on shell)
walbro 255lph pump,
aem regulator
bdl fuel rail custom coated
modified type s injectors
innovative mounts
hybrid racing swap harness
k-pro
itr booster
brand new itr master cyl
rs brake lines/40 40 prop valve
abs is deleted
koni yellow shocks
eibach sportline springs
ssr lca's
rs front seats
bride shift boot
faux itr cf interior
jdm itr pedals
itr rear seats
alpine ipod deck
clock delete
jdm itr cluster
k24a4 block from 2005 accord (about 3k on motor)
12.5:1 cp pistons (rings spec'd between all motor and nitrous)
blueprint I beam rods
oem bearings
steel k24 pan
k20a2 oil pump
k20a2 head
k20z1 cams
shaved/ported rbc manifold
k20a2 tb
karcepts cold air intake
custom powdercoated valve cover
carbon fiber plug cover
04 type s transmission w/ oem type r lsd
transmission in great shape
comp clutch stage 4
r-crew header
magnaflow resonator
3" thermal exhaust
drilled and slotted rotors
karcepts shift plate
buddy club shifter
oem rsx type s shifter cables
tucked battery
tucked bay harness
stock 02-04 type s engine harness
No joy rides
Phone: Call/txt 502640159five
located in Louisville, KY...
Thanks for looking and please bump!
sleeper status like whoa.. i bet you surprise the hell outta people with it.. lol
