H22a from civic to integra
The Godfather
Ok so I have a eg civic hatch with a h22a and prelude gearbox to match... Civic has Hasport engine mounts for h22a
I'm sorta over the civic shape and would like to swap all the stuff from my civic into a dc2 integra!
Will everything be a straight swap over?
Can I use the shocks and springs from civic to Integra?
Any help would be greatly appreciated :)
Thanks
you can swap it all over to a DC2, but as was done in your civic, you will have to cut the center tunnel of your car to mount the prelude shifter assembly and route the shifter cables.
is the cutting of the tunnel straight forward? is there a template anywhere? i never had to cut the tunnel out as i bought the civic with it all done...
he means if your tunnel is not cut already you need to set your shifter and cables on top of the tunnel and mark your oval cut out at base of fire wall and tunnel meet and cut your shifter hole wider to fit shifter assembly,if this helps give me some rep,good luck,lol... your cables will set on top of your tunnel and go through the hole at fire walland make sure you put a rubber gromet on edges of hole to reduce cable tearing or put protective foam around cables...
take the center console out of your integra, look at how the cables a routed and shifter was installed. Copy then paste into the civic chassis.
Only he will want to do it the other way around as he wants to put the H22 into a Teg from his Civic. Yep it will be a straight swap out to the Teg chassis.
