Wassup everyone I got a 92 civic eg hatch back wit a d16zc sohc v tec im swapping out for a 92 95 b16a and I would like to kno wat I will need . i have motor.and trans but I think ill need axles and a shift linkage and half shaft and ecu so my question is is this all I need . What year and make and model should I get the doner parts from thanks
Correct. OBD2>OBD1 harness, and you'll need to have someone chip your ECU. Basically enable it to have a different fuel map put on it other than the stock map.im sorry could you explain the chipped and socketed part and so i would have to get a OBD1 p75 and a OBD2 to OBD1 harness correct?
I am in the process of doing that now. VTEC conversion kit, VTEC water pump, oil pump, timing belt, head studs, and wire the VTEC solenoid.
All of these things at the very LEAST.
