Do i need to align my car after disc brake conversion?
hondalife97
I am gonna do a disc brake conversion on my ek and it need some alignment right now. I am converting all my brakes to integra brakes .
anytime you mess w/ suspension, whether it just be raising or lowering your coilovers you always need an alignment afterwards
if you are converting the brakes i dont see a need for alignment. but otherwise, what the nazi said.
The brake system rides on the hub and does not affect suspension geometry.
If you replace the trailing arms (what most people do) then you should definitely align the suspension. If you're just replacing the hubs, then no.
Ah yes, if suspension components are replaced, it stands to reason an alignment is in order.
