makemagick
So, I got a 97 integra, and a obd1 jdm gsr swap. instead of the gsr intake I used skunk2 intake manifold. As soon as you start the car the revs go to the skies 3-4.5 and it feels like someone is pushing the gas pedal but no1 is really pushing it obviously. I tried to search it on the forums, a lot of people suggest to change the manifold gasket (obviously i did since i was installing a new manifold). i'm pretty sure all of the hoses going to IM are correct too. So far the only solution we found is to close one of the valves in the throttle body, as soon as you cover it with your finger RPMS go back to normal 1.7ish. Any suggestions?
