I have a 1993 honda civic with a d15b vtec engine. Need to get a pulley for the crank shaft. Does anyone know if the civic and del sol carries the same crank pulley. Kind of confused. On the internet there are different descriptions.
I would assume your talking about a light weight crank pulley / under drive pully??? or are you talking about the stock pully? A 1.5L non vtec crank pully should be what your looking for, a d16 is bigger than your stock block. a Del sol came threw with 3 diffrent motors...
Its the under drive pulley otherwise known as the Harmonic Balancer. This one is for the1.5 civic lx and dx model and also the 1.5 del sol. Can u say if this one will work
