Cooling System Woes
SlushboxTeggy
It's only stupid if it doesn't work
VIP
I just installed a new radiator in my Integra. I'm still losing coolant and actually almost overheated this morning coming into work. In the past week I would come out to the car and see a small puddle under my car. Other times there was nothing. I can't seem to identify where the hell it's coming from. I highly doubt it's the new radiator, and both radiator hoses are still in decent shape. I'm stumped.
I'm going to check my thermostat when I get home just to make sure it's working, but even if it was stuck closed, could that cause my system to burn off coolant? Any ideas or experiences are welcome.
an open/stuck thermo wouldn't leak fluid-- you'd just have a problem warming up when its cold as it would always cycle.
If its not the rad or a hose, it's the block or some other water passage :( check your oil. is it green?
I'll check it after work. I really hope not.
I was losing coolant. The filler neck on the old radiator was cracked and I could literally hear the coolant steaming out. I guess it wasn't the only spot I was losing it.
Make sure you dont have any air pockets in the coolant, as this will cause an overheat condition, or worse... A busted head or head gasket. You need to make sure to BLEED OUT ALL THE AIR, making sure you have good heat in the cabin, and that both hoses are the same temperature...
Radiator & Cooling System Pressure Tester Kit
...although, if you just installed a radiator, and it wasn't losing coolant before, but it is now...you either cracked the radiator or you didn't tighten a hose down.
Why'd you replace the radiator?
This is the way to go.
Cooling system problems can be a real PITA and phuk your engine into oblivion. Trying to isolate the leak when it's running and hot can be difficult and is just too phukin dangerous to be worth it if you can't see it spewing without bending over and moving face and eyes closer.
I'm suspecting head gasket or heater core.
If there are air pockets in the cooling system, it will seem as if coolant is being lost.. But if a pre existing leak was present, and coolant keeps disappearing, without any obvious visual leaks, pull the plugs, see what condition they are in... A leaking head gasket will be VERY apparent on the plugs...
^ It will only show up on the plugs if it's leaking to the inside, and of course, not if it's leaking to the outside. They don't always let go into the cylinders or cylinder to cylinder. That is the most common failure, but they can and do leak anywhere.
Got out of work at 9 last night so I didn't have time or light to check anything. Didn't have a puddle under my car when I left though, so IDK. I'll be able to check it tonight.
And I did make sure to bleed the system when I installed the new radiator.
ah, ok then, rule that out... hey, how full is the overflow tank?
It's to the max line when I fill it.
The leak is on the backside of the motor. Not the head gasket(thank ya Jesus!). The leak is lower down. It's dripping down the back corner on the oil filter side. Can't really get in there to diagnose it further though. Any ideas?
Car is coming due for a new timing belt and water pump anyway. May just have the guys at work do it for me (I don't have the time or tools). If that's not it, hopefully they find it while they're in there.
I'm off tomorrow and it's suppose to be nice out. I'll be able to take a more detailed look. I'm getting sick of topping off the system.
Just as an FYI...my swap wouldn't leak a drop unless the coolant was warm/hot. It would leak some after I ran it......and then stop. So, I would look (carefully....hot water make me say ouch) after you drove it for a bit. Might help you find the culprit in action and no after the fact. A hex head plug was leaking on my BNIB radiator (some universal hole for a rad switch I didn't use) thread were bad on the plug. JB Weld saved the day for me.
That's not looking good if it's leaking by the oil filter.
Only things back there are the filter, the knock sensor if your lock has one(not on ls) and the big screws with plate heads that the Endyn style catch cans had return plums to put the oil back into the block.
Ie, not a water jacket...
You may have a cracked block :(
Hopefully it's higher than that and just dropping form the IM or something else instead.
It's not actually from the filter. I more meant from the driver's side/filter side of the block. After some searching online, it seems like it is leaking from the water pump. Best case scenario in my mind because it was coming due anyway. I'll look tomorrow when I'm off, but I may also come into work just so the mechanics can get it on the lift and take a better look. If it is, nothing like getting a timing belt/water pump change for the cost of parts + a case of beer.
What about the tube that runs from the thermostat housing to water pump inlet? Is his model engine configured like that? Like any of my old D16's?
Good point. Could be the tube, the O-ring on the end of it, or the pump itself. I may just sack up and replace them all. At least the O-ring and the pump/timing belt.
EDIT: Really hope it's not the pipe. I can't seem to find a replacement anywhere...
