Um, I don't think so. Even if it were possible, and you went to hella expense to make it work, your compression would still be low. Not feasible, it would be cheaper and easier to install an H22 complete.
its very possible. there are several write ups on this. here is one of them. it is feasible. it wouldnt cost 2000 to have done. if you were going for boost then its not a bad option. however because you compression will be so low its not going to make for a good n/a motor with out the proper equipment.
Honda-Tech.com: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
