95 integra motor into 97 accord
lowbravada
What all do I have to do to put a 95 integra motor into a 97 accord?
I wrecked my 95 integra and found a 97 accord that needs a motor.
Thanks in advance for any help and i'm sorry if this is in the wrong section.
You'll need new mounts, most likely custom. Along with a lot more. Personally I think it's more work than it's worth. Try and find a motor for the Accord (F22, F23, H23, etc.) as they can usually be had pretty cheap, and save the B18 for another project.
yep, it will be underpowered and require a ton of custom stuff as this is basically going backwards.
what do you mean?? question is not clear
so you are asking what its worth? realistically you will probly get about $1500 for it, but it does depend on the demand in the area where you are selling.
It's worth more than enough to cover the cost of the Accord motor, that's for sure. Does the Accord have a transmission, or do you need that too?
One thing to keep in mind is that H-series motors will bolt right in to that Accord, so you could easily do an H23 or H22 upgrade instead of a replacement F22...
Thanks thats what I wanted to know because I can get an f22 for around 650 here
Seriously dude I can ship you gsr engines for 1000 all day and make good profit.
High mileage gsr is going to go for 400 to 600 tops. If the tranny is in good order you might get a bit more for it than 400.
Good choice because I also believe It's illegal to have a motor older than the vehicle you're installing it into...
It is in about 40 states in the union, so it will hurt re-sale long term.
