I was just wondering how much power can a built head give you with the stock block? skunk 2 pro 1s, aem adjustable cam gears, skunk2 valves, springs, retainers and port and polish.
basically what they are saying is there is no real way to tell how much power u would make.. depends on the tuning\ tuner. could gain 50hp to 2million.. no real way to tell. real power will come from if u build the block to tho. more relaiable to.
moving to a larger cam without adjusting the compression ratio by using a larger dome piston is like body building, and never doing legs. insert that pic here.
Thanks, and yeah I will build the block eventually, i know it is kinda dumb to build part by part, but i dont have enough finances to do it all at once, so since the head is easier to take out I chose to do it 1st, but thanks anyways
