this is what i have gather so far from all my research
there seems to be a few things missing, i know the swap is the same as an h22 everything pretty much bolts up except for the wiring.i know wiring the IACV will be a problem because it goes from a 3 to a 2. i think i read somewhere about the thorttle cable either being too short or too long i forgot which. I would have to do the knock sensor. I am sure there are other things i am forgetting or missing.
can anyone point out what parts i am missing for this swap
Currently i have
F20b Motor
H22 headers
H22 Skunk Intake Manifold
97 lude IACV
95 lude Distributor TD-61u (converting to OBDI)
95 lude water pump
using my stock alt/radiator
Prelude Power steering bracket
P13 ecu
HASport drivers side mount (not sure if i need? can always sell if i dont)
not sure what spark plugs to use i was gonna just go with NGK
Currently i have
F20b Motor
H22 headers
97 lude IACV
95 lude water pump
P13 ecu
