Help with auto cov into Ef plz answer
cardinalboy07
Ok. Hg I got an auto b18a putting it into Ef
I replaced flex plate with flywheel
Got cable Ls, 5spd I. M. Ef b Series mounts
Now the auto t bracket. Bolts up to 5spd trans all bolts went on, no misalignment .. Can I use that t bracket or no?
Also since motor is auto can i still use auto half shaft and axles
As far as the half shaft goes if it will fit into the transmission then it should work no problem but to be honest with you ive always seen them sold either for auto or manual im guessing it has to do with the spline count on the shaft.....so if u have the pieces just mock it up and see if they all go together and there is your answer.
i thought the auto and manual use different axles... but i could be wrong. like m90polk said, just try it and see.
the Integra axles are the same for manual and auto - the intermediate shafts may be different
