makemagick
once in a while i let my car go on neutral from any speed, and while its rolling the RPMs are around 1.5 and they only go down once you come to a complete stop, there is a crack in the plastic of my TPS so i was wondering if it could be the TPS sensor fucking with my RPMS.
Oh and also when i just start the car my rpms drop down to 0.5 and then the car goes to 0.7 while warming up, after it warms up it goes back to normal around .8, however if you rev it right from the start (to like 3 rpm, just a slight gas pedal kick) it start from 1.0 1.1 and goes down to 0.8.
I'm running 68mm blox throttle body, and there is no idle adjust.
