you're all wrong.
attach engine to hoist and lift enough for tension on chains. attach it level (after removing axles and disconnecting harness/hoses)
release mounts
put a small tire, or little engine dolly underneath and lower engine onto it.
release engine from hoist
if no lift is available:
attach chain of hoist to the driver and passenger side mount with the mount bolt
lift front end of the car enough to slide the engine out. .
