School me on air filters
Briansol
Admins
Admin
VIP
I need to replace my cone filter on my car. it's beyond re-washing at this point (it can probably be saved, but i'm too lazy to bother with it for the price of a new one)
So, There's like 32432432 different types of universal 3" cone filters apparently.
Is there any advantage to this top
http://www.knfilters.com/search/product.aspx?prod=RC-4650
over the standard flat top?
http://www.knfilters.com/search/product.aspx?prod=RU-3580
And what about shape? it's steeper... is flatter better?
http://www.knfilters.com/search/product.aspx?prod=RC-4290
vs flat:
http://www.knfilters.com/search/product.aspx?prod=RE-0930
Or is it simply about fitting in the allotted area?
I'm leaning towards the 3580 right now.
this is what i have now:
Since cooler and a higher volume of air is better I would assume whichever flows the best would be better. They will all be in relatively the same place so I can't imagine any of them are cooler than the other.
brian i've got one new in box. if it fits you can have it for 20 bucks. it's a spectre for a 4 inch but can muzzle down to 3 and 3.5 .
i'm running a K&N drop in replacement OEM filter in the VT.
A velocity stack and filter is a possible combo. Probably get one that slips onto your existing pipe.
Meh, filter's a filter. I've used all sorts of different shapes and sizes, and at the end of the day, I'd recommend buying a 'better' brWand that won't fall apart over a lesser expensive one. Other than that, whatever. A velocity stack with a big ol' mushroom tip is what I went with when the race car was N/A, and I recall back in the day Philip / Intercrew / Mike saw some good gains from a velocity stack with a big ol' mushroom tip (which is the reason that I went with that on the race car).
Would recommend 3580 or that style (solid rubber top) over a 4650 or that style (metal glued-on top) as I've seen those come apart on high horsepower cars and cause more of my bills to get paid.
Get the biggest K&N you can shove in there. Some of them have built in velocity stacks now so you don't pay some hack job a ton of cash for an aluminum penis extension.
