slicker2ya07
So after replacing my head gasket got it all put back together mostly (motor mount, alt, power steering) are not hooked up yet.. Alt is plugged in.. I push the clutch and turn the key I get nothing.. Replaced the starter thinking the solenoid was junk but that failed.. Not even attempting to turn over. I am guessing its the main relay but want a second opinion. Everything besides what I mentioned above is hooked up.. After turning my key to try and start it check engine light comes on really dim and something starts buzzing under dash.. I let go of the clutch buzzing stops.. As stated will not crank.. And even trying to short the solenoid to crank it still nothing.. I WANT MY CAR BAAAACKKK .... WAHHHHHHHHHH lol.. Miss my 20+ psi 2 door badass..
