1991 Dodge ram 250 - Transmission Rebuilt!
awptickes
unimpressed by you
VIP
131k on the clock. 4x4 works, Corporate 9.25 in the rear, dana 44-8 in the front. 318ci v8 in it, with all of the emissions stuff, and no engine codes.
It needs:
Transmission bands adjusted
Transmission fluids replaced
Transmission filter replaced
Rear Brakes
New windshield
Alternator fixed
Rear roll bar removed
New tires (probably going to throw used tires on it)
You'll see... :D
This is going to become an interesting vehicle.
Vehicle Description DODGE POWER RAM W250 PICKUP
Model Year 1991
Body Model AD 6 L 62
Color PE4
ISD 07/10/1992
Engine ELG
Transmission DHHS- Shift-on-the-Fly, 241 Transfer Case
Sales Code Description
ADAP Light Group
AHH Light Duty Snow Plow Prep Group
AKB Colombia Equipment Group
APAS Monotone Paint
ASHP Voyager Spring Special Package
BANP 120 Amp Alternator
BGKS 4-Wheel Anti-Lock Brakes
BKHS 12x2.5 Rear Drum Brakes
CBAP Straight Back Bench Seat
CDEP 6-Way Power Passenger Seat
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CURP Rear Compartment Storage Tray
DGB All 4-Speed Automatic Transmissions
DGRS 4-Spd. Automatic 46RH Transmission
DHHS Shift-on-the-Fly, 241 Transfer Case
DJEP 5,500# Front Axle w/Hub Ext
DMHS 3.92 Rear Axle Ratio
DRGS Corporate 9.25 HD Rear Axle
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GPBP Blind Spot,Pwr,Fold Pursuit Mrrs
GVAC All Vehicles W/O Power Mirrors
HCAS Heater
JCDS 100 MPH Primary Speedometer
JHAP Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JKAS Locking Glove Box
K17P Do Not Use
LAAP 3rd Row Seat Belt Alert
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LMAP Halogen Headlamps
LNCP Clearance Lamps
LPEP Cargo Lamp
MBBS Bright Front Bumper
MBF Bright Rear Bumper
MFDP Bright Grille
MHAS Black Windshield Moldings
MKAP Do Not Use
NAAS Federal Emissions
NBKS EVAP Control System
NEMS Exterior Sound Control
NFEP 24 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NMCP Heavy Duty Engine Cooling
RAAC All Radio Equipped Vehicles
RALS AM/FM Radio
RCDP 4 Speakers
SBAS Power Rack and Pinion Steering
SCBS Perforated Steering Whl w/Red Stitch
SFAS Standard Duty Shock Absorbers
SGAS Rear Shock Absorbers
TBB Full Size Spare Tire
TBMP Tire Carrier Winch
TZAP Goodyear Brand Tires
WDAS 16X6.5 Aluminum Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMAS Black Hub Caps
WMCP Bright Wheel Trim Rings
XBS Pickup Box
YAAS Build To U.S. Mkt. Specifications
Someone local on FB has a parts truck. I'm going to try to pick up the windshield and driver side mirror tonight.
Leave the rollbar. It's ugly, but it's fitting. And that's not a cut on the truck. It just looks right.
TBH, I'm not sure I could lift the roll bar myself, lol. It's just a shame it sacrifices so much bed space.
Flushed the cooling system tonight.
This truck is going to need quite a bit of work. It's nowhere near as mechanically sound as the RamCharger is.
I'm conflicted: If I put a lift on it, it won't fit in the garage. My wife only tolerates it because she doesn't have to look at it outside the garage.
I feel like it needs a 4" lift with some 35" tires. The 31" tires don't cut it.
Yeah it does take up some space. So, with all that said, yes! Trim the fenders and throw 35s on there. But why stop there? Throw some flares at it. Wedge cut and narrow the bed. Go with fabricated bumpers and skid plates. The roll bar already screams trophy truck. Don't stifle them.
35" tires it is. What's kinda silly is that those tires will easily cost more than I paid for the truck.
It already has the stock dodge skid plates. I've got some 1/4" sheet that I feel like needs to go on it to protect the transmission and transfer case. The RC came with those bits stock, but Waylon doesn't have any of those. I just have to get a torch so I can bend it rather than cutting and tig welding.
Just make your garage door taller.
Can't do that, I've already considered that a couple times. I can get another inch of clearance by going from a standard garage door to a roll-up, but I don't think the roll-up doors look as nice outside. A roll up would mean I could put a hydraulic lift inside, but the lift would only give me about 3ft of lifting because of the loft upstairs.
None of the ground on the property is level. I'm not going to build a barn. I may, however, re-investigate roll-up doors that don't look like shit. That'll give me another 1.5" of clearance.
