Cobra Globe 3100 wiring
Nick7
Well, as recently did my swap, I also swapped out wire harness during that mechanic cut off wires of my alarm.
I have Cobra Globe 3193 (3100 series).
When I bought it, it was installed at a shop here in Croatia, and for manual I only received localised user guide, which doesn't say anything about wiring.
Anyone knows what wire is for what?
On Cobra web site I only found manual which says where to connect each function as in: power supply connects to XYZ, immobilisation point to YXZ, direction indicators to YZX, etc...
But, I need to know what colout wires are for 'immobilisation point', 'direction indicators', etc...
Help?
PS: I prefer to install it myself.. and I don't see reason why I need to shell out $$$ for such easy job... if you have wiring...
Community spirit is SO impressive here.
;) Just got to laugh at you lot- Community spirit is SO impressive here:rolleyes: .
Someone asks a question:confused: , no one gives a particularly helpful answer :eek: (but I suppose at least one person could be bothered to type something), and the poster doesn't even bother to post back:p to say if he ever got the info, or give it to help others. You Honda owners don't really care :( about each other do you?
Well here it is from a non-honda owner :cool: as example to you lot, whether you are a senior member, the original poster, or one of the many others who just dont even attempt to offer help :ph34r: ......
Red + 15A
Black -'ve
Pink Door/boot switches
green/red switched +'ve
Yellow- Indicators
Green- cut off
Pink/black- speedo signal
grey US module
Brown- additional modules
external siren?
red pin 15
yellow blue pin 14
black pin 12
those other little sockets?
LED - LED/switch
Tx US transducer
Rx US transducer
Y aerial
Hopefully you can work it out from that :confused: ?
I know it is late, but at least there's an answer :D for the future if anyone needs it. Courtesy of a non-Honda owner :) - it seems that's the way to be if you want to be helpful :rolleyes: .
Help?
Wow. I'm sure he has waited 3 years for this info. Now he can finally drive his car again. Thanks man.
Hey Cal, I think we got another winnAr!
You are SO impressive
So VERY impressive.
And as much use as a chocolate fireguard, YOU waited over 3 years and STILL never helped the guy.
Yes, very impressive!
MMMM chocolate firewall...
I'd say our posts were equally helpful, since the OP hasn't posted since February of 05, more than likely already resolved the situation and probably doesn't own the car anymore. But If anyone else has this problem, I'm sure your info will be helpful. Props to you for answering an "age old question" :D
