WOOT WOOT WOOT
formby
learning in progress
IT FUCING STARTED
THE CRX IS ALIVE
IT WAS A FUCKING FUSE!!!!!!!!
last night i decided that if by today the rex did not start i was going to do the ek swap...i did not sleep that well, but i woke up at 12.30....
any way i take the car off the stands, take it out of the garage and put on the battery, same relay i put n my other post, and a volt meter....i started in the cabin and i checked the fuse box one fuse i remember fixing was blown
so i cheched my book and i had put the wrong fuse in it ....well i fixed it ....the pump turned on and the engine turned over on the first try...
since fucking JULY...... OMFG....i am finishing a joint and i'm changing the oil and putting the rad back in.... :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool:
nice and here you have been trying to sell it and part it out for some time, bet you glad you didnt sell it
kinda.......i think i might sell the rolling shell....and do the ek swap
its throwing a code 4 Crank Position Sensor....i think its because when it was sitting i turned the crank to make sure it wasnt stuck.....
do i just put it back in time? or do i have to remove the timing belt and reinstall it?
yup...and i stopped working on it until the points on my licence went away
i just got back from a ride....the fuse blew twice....thank god i was by a walgreens...WTF could be blowing that fuse
should i check for burned out lights....exposed wires???
ive never had to do this before :ph34r: :ph34r: :ph34r:
first tell us which fuse it is
i would check for continuity between wires which should not be connected...
i dunno???? do i remove the ground from the battery or something??? to check th alt
after so long of not driving it. i forgot how loud it is...
so i bought this
and this cheap silenced can...
and i have an 18" resonator already on there....
i'm going to use this for now until i finish the turbo kit...then it goes on the HB
do you guys think that magnaflow will quiet it down??
BTW... i'm going to run the muffler straight out of the back... i think that looks so sick on a rex
I also wanted an odyssey batery...which one is the one i need....and are there any other brands i can look at????
