hey im dropping a b18a1 into a 89 hatch and ecu connects to tha connectors do i havr to do ne other wirring? also do i have to put after market motor mounts on it? what all do i have to change plesase help me thanks
yes on both counts.
do a search newb.
if youre car is a dx or standard you need to wire in the additional injectors and you will also need to extend a few wires.
Hasport mounts are what most people use, but there are other brands as well.
serious an LS swap into an 88-91 civic is the most common swap ever done, please do a search on the subject before posting your questions. its been covered numerous times.
I have everything i need to do this swap except the motor mounts and axles. what else do i need to do to make this a great swap. Which axles do i use. Can I custom make my own motor mounts. What is DPFI to MPFI?
