93delsolsi
Broke a bolt to the cams caps and can't get it out & Yes i was torqueing it with the torque wrench so don't go on blast with me just need some Help
sorry it aluminum caues there like for of them and the rest is steel you want to to take a picture
center punch y0You won't get a clean drill/tap on a hardened steel bolt stuck in an aluminum head.. the drill bit will slip off the steel and make a mess, no matter how steady handed you are.
