How are these endlinks supposed to work?
SlowEgg
I need paint.
It says they are for 1988-2000 Civic, and 1990-2001 Integra. I just dont understand how they will work. Which end fits into the sway bar, and which fits into the control arm?
those are for the front im assuming?
doesnt matter. they are the same top and bottom. fit the control arm between the bottom two red bushes and the sway bar between the two two bushes.
They are supposedly for the rear. They do look alot like the fronts though. If they are the rear, there needs to be a "stud" that goes front to back (for the LCA), and one that goes to the side (for the sway bar). All resources indicate, however, that these are for the rear. They "should" look like this:
evilbay is evil stay away no matter how the deal sounds.
Remember if it sounds to good to be true its generally bad.
