the mirage is fixed. video inside. updated sept 22
the story is this. i'll be blunt.
i downshifted to 2nd at 90mph. chaos ensued. that is all i will say.
symptoms i have had since the incedent-
car BOGS from 4700-7000. sometimes i will get lucky and for a brief moment the car will have full power in that range, but then still bog. from idle-4700 power is normal.
stuff i have changed-
spark plugs
plug wires
dizzy cap
dizzy rotor
I EVEN pulled off the timing cover to discover i was OFF by 1 tooth. fixed that, rotated the motor a few times and it was perfect. put it all back together. same problem.
what i havent changed YET but is next on the list-
fuel filters
crank angle sensor??
actual distributor
im tossing a new code, i just havent read it yet. if i reset the ECU, the code pops up within ~20 miles.
input is appreciated.
spark plugs
plug wires
dizzy cap
dizzy rotor
fuel filters
actual distributor
