PR4 CONVERTED TO P28?help!!
StealthMicro
HI,Iwas wondeing if its true that i can run my pr4 ecu,obd1-so it operates my d16z6 /vtec like a p28,can it be converted like that?any one got a link showing how?
You can't use an obd0 pr4 on an obd1 system; you'd have to convert your car to obd0, which would be dumb. I believe you can do a 1-wire vtec conversion on obd0 pr4 ecus, but it's prolly in your best interest to avoid the hassle, and spend a little extra cash on the p28. They aren't all that expensive. But go on to pgmfi.org if you want to learn more about ecus, there is a LOT more information than you'll ever need there.
