What? No, don't listen to this douchebag. If you have hasport mounts you'll be ok, but if you're using stock mounts you need all 5 mounts. Without the front lower mounts your motor will move around too much, and you risk breaking things such as sensors, axles, etc.
Don't halfass your car, do it right the first time.
+1, youll be safe, but your engine wont. And even if you have hasport mounts, your still going to seriously put those MM though hell, and wont last as long as if you had all your mounts. Your car will also jerk funky too. My merc had 2 MM at when I got it, and it was gut renching driving it to Mech to fix (it was a 77 240D, im not rich).
Does anyone have any idea where i can locate the front tranny mount and the a/c bracket/mount, our salvage yards around here are gay and none of them will sell them to me. Thats whats pissin me off with this. Thanks James
I bought just a b18c motor and trans, not a whole front clip and i found the 2 (the back trans mount, the right front trans mount) of the mounts i needed on ebay. if that helps. I've seen the ac bracket on there recently.
