t4 t61 turbo on built h22a1 on 10 psi of boost
turbowagon92
i just got in my new turbo t4 t61,my new turbo is replacing old model(don't know specs).my h22a1 engine is gettin a stage 3 head package and my block is rebuilt from previous owner just changing forged high com. pistons with mahle gold series piston kit.main and rod bearings have to change.the block is being put together with cometic head gasket,arp head studs.i have 720cc injectors,255lph forced induction fuel pump,accel ignition,hks spark plugs,and nology wires.what kind of power can i get out this set up?this work is done in my 92 honda accordwagon.the computer id bing tuned by crome.:confused:
what psi do you intend to go to? your injectors will limit you probably to around 450hp.
10 psi on a t61 is gonna run at about 350-400.
If you already have a sleeved bottom end, id recommend going with a different piston. Check out JE, Wiseco or CP...all three are pretty good.
10psi mahle 8.9:1 gold series piston kit non sleeved buit block,stage 3 head
the block is built but not sleeved.i only want 10psi right now.there is alot more involved,block sleeving,high horsepower rods and aem w/uego,500 hp+axles,lsd,1000 cc injectors,3bar map sensor,1.3 bar wastegatespring,and stage 3 clutch upgrade.my hondawagon on 10psi is fine for now.the suspension needs to be upgraded(take out springs and go to d2 racing coilovers) before anymore upgrades under the hood.i bought those pistons to set up for 10psi on a stock sleeved block.mahle gold series pistons are made to run on stock sleeved block.oh yeah,i found out my rebuilt block was not sleeved for sure no guessing.:mellow:
