96' Accord Door Lock - HELP!
atari52oo
Help!
My automatic door locks won't stop trying to lock themselves! When I hit the door locks, all of the locks will lock, and then keep trying to lock until I either push the button to unlock the doors, or I pull up on the drivers lock pull. The same thing happens when I lock the doors with the key from the outside, or I push down on the drivers door lock.
Any ideas were I should start my troubleshooting? Could this be a relay issue? or maybe something with the lock pull inside of the drivers door?
Thanks in advance for any help!
okay maybe the brain is going bad...?
take them of the put it back to normal without the alam.... you have to do it fast
because you can bern the motor.....
good luck
thats what i was getting at as well..usually the source of a failing power options (door locks, windows, alarm, etc) is usually contributed to a module or brain of some sort thats gone bad.
