do you think i can make 200 hp on a b18b1 motor,at 5lbs of bosst with out having to mess with fuel tuning and all that iam moving somwhere were a dyno is not my motor has about $3,000 inthe motor. newly rebulit, bored out.020 over balanced egale rods je pistons , scalloped golden egale block gaurd iwanna do one or the other. iwant 200 HP. ls/vtec is another option but iwas told that 9;21 c/r is to low to make high HP #S so,ihave a nice bottom end with itr (oem)oil pump i just need some help man. ive been answering ???????? all night no one has aswer any of mine .ill be happy with 180HP on a ls/vtec my block now is pretty much a1.9n now if tat helps .idid the Honda motor HP calculator thin wit 2 layer gasket b16 head ishould be able to hit over all c/r 9.9888 almost 10 this car is also my daily driven car ivw put a lot of money into it .the tranny has a b-16 hydro 8lbs flywheel car runs great put me in the 14.7 =1/4 mile time .iwould prefer boost but i dont wanna be down by the dyno shop with problems 200HP will make me happy and as a daliy driven car or streetcar i would be happy with that i just need som help .my bottom end is all set for a prpper ls/vtec.
Ps - You need to work on your grammer. I could not understand half the stuff you were saying.
It's grammar.
