Money, you're welcome.Thanks.
+time, and lots of itMoney, you're welcome.
I am not swaping that engine, but Im sure you'll need these basic things;
F series motor mounts into 92-95 civic or del sol, or 94-01 intergra
drive shafts for that swap
ECU (computer of cylinder head you are using, in most cases)
a wiring harness for that motor swap
hasport sells a lot of these parts, they're expensive but the best!
if you could find a buddy to wire up your old harness with the F20c harness, that might save you some money. I seen someone does this on ebay, sells their services.
well since no one helped you ill be happy to help, im running h22 in my eg coupe
youre gonna need
h/f series mounts (hasport.com, avidracing.com)
wire harness
cable shiftlinkage
ecu ( im running p30 tuned with crome)
axles (right axle 94+integra, left axle 92-93 integra)
thats only the main shit cause you still have so much other stuff im not even going to name that you have to do here
SEARCH just a little bit, like the guy before me this is just the a general list
What? Are you retarded? The F20C will not bolt into ANY civic with Hasport H/F series mounts. The F20C is out of the S2000, it's not remotely similar mount-wise to ANY other H/F/B/D series motor.
oh shit my bad for some reason i was thinking f22, no its not similar and also the fact that its a rear wheel drive i dont know what i was thinking, but anyways all thats for the h22 or f22 into an eg............. NOT a F20C...obviously im somewhat retarded
No prob, everyone makes mistakes...
I actually know someone who did it, but it's super-top-secret how they did and I'm not even supposed to let anyone else know that I know about it, and it was FWD...he called it his 'special K-series'
