Brake Upgrades
Uppertorso
Hey guys, I have done a B16a swap into my 4th gen civic, now I am finding that the brakes are a little under par. I want to upgrade the front brakes to integra style rotors/calipers/bracket. What vehicle would I take all of these parts with??? I have tried to find this info, but to no avail. Thanks in advance!
:blink:
:blink:
I have a DA that is about to get strip. Because I'm salvaging parts from it and also got a DC2 Integra. To me it look the same and measure the same I believe so.
They are both the same and bolt right in. I have a 90 crx si with the b16a1 swap and I have the 'teg brake calipers , rotors, and knuckles. but I think they will only fit if you have 15 in. wheels or bigger.
Hello,
I've got '91 CRX Si with a B16A swap made. Now I'd like to know if complete front brake system (262mm) from EK4 ('98 Civic VTI) would fit. I know it fits into EG and I heard also that EG front brakes fit into EDs. Do I need a camber correction kit?? My wheels are 15"...
as I understand it the eg stuff is different than ed. 90-93 teg front will work but they are about 11" so probably wouldn't work with small wheels. Also good to run the teg master cylinder
Yeah but I need info about EK4 brakes converstion into ED..I know EK and EG are almost the same, but I need to be sure...I heard that EG brakes (same as in DC2 4x100) fit into ED...and EK fit into EG...but I need short answer about putting Ek brakes into ED...sorry :)
you can change the mas. cyl. but you don't want to use the teg. one. the one you would want to use is from a 91 ex civic sedan 15/16" and this way all the lines are in the same spot
Get the 90-91 Civic EX steering knuckles, then bolt on Accord Wagon calipers if you want to go to 11" rotors. Search "4G brake upgrade" on Google and I guarantee you'll find what you're looking for. You want to look at the old hybrid-honda and crx.perf sites.
