rs/vtec info obdI head to obdII
1badteg
ive got a 96 rs integra. im in the process of picking up an obdI gsr head (95) and need to know if i can just swap out the vtec sensor on the head and all other sensors to obdII and be good? ive got a p72 obdII ecu as well. anyone willing to part with an obdII vtec sensor cheap?
yea should be able to swap out all the sensors with the ones you already have in the integra and it'll all be obdII, i'm not sure about this but i don't think the vtec solenoid really matters in the case of obd's i believe they were all the same for all the years, don't quote me on that tho
Do you mean putting the gsr head parts on the rs head?If so no you cant.
Its called an LS/Vtec. Do a search and you can find out what you will need to put a vtec head on a non-vtec block.
